while you perform a visual inspection for leaks starting at the reservoir, and working your way to each brake line/caliper, as needed. Should be obvious where the leak is very quickly. I just replaced my master cylinder a month or so ago, pretty simple job.
------------------------- Everything I need to know about life I learned from TT.net
